Re: 'C' Radiator
Posted by Haas on February 27, 2003 at 06:58:46 from (166.72.245.123):
In Reply to: 'C' Radiator posted by I RIGHT I on February 27, 2003 at 02:46:34:
There are two kinds or radiators on the IH tractors. Most of the later ones are pressure, but your C could be a not pressure radiator. The same pressure cap should fit the M, H and C. If your C had a gas cap on it, it is likely non pressure. In that case, you need a non pressure cap. You can tell by looking in the top of the radiator opening. If there is a small tube sticking up from the offset just inside, your radiator is non pressure. That tube is the overflow. On the pressure radiator, the overflow will go out the side of the neck on the back side. I think only the very early Ms and Hs had non pressure radiators. Aftermarket radiator caps are available for the non pressure radiators.
Post A Followup
: Re: Re: 'C' Radiator
