Re: Re: Re: Would a two-bottom plow for a 'C'
Posted by Bill Smith on February 27, 2003 at 08:54:42 from (128.242.4.59):
In Reply to: Re: Re: Would a two-bottom plow for a 'C' posted by Gary The Rookie Farmer on February 27, 2003 at 03:46:35:
Well, that doesn't really help me much. I would guess that the plow is in fact drag (pull behind) but don't know for sure. Ask the owner and if he doesn't know, then you will have to go look at it yourself to find out for sure. Plows of the same era as the H Farmall were typically drag, with a trip system to raise and lower. The newer style era was either 3-point style or pull behind with hydraulic lift. Some of the real small tractors had a 1 row mounted plow. No knowlege here as to whether a C had one or not. Cultivaters in the same era as the C and H tended to be mounted.
Post A Followup
: Re: Re: Re: Re: Would a two-bottom plow for a 'C'
