Re: 140 hyd pump leak
Posted by Paul Shuler on February 27, 2003 at 15:39:26 from (66.119.2.82):
In Reply to: 140 hyd pump leak posted by Ed on February 27, 2003 at 14:08:42:
If you mean the pump just forward of the distributer it is an easy fix. Most often it will be one of the O rings.Blew of mine out back in Dec by raiseing the two point lift without allowing it to warm up a few mins.{8 degrees out} and blew out my O rings. fixxed it out in the snow in about 30 min.s Had some cold fingers though. Hope this is your trouble cause it's no big deal.
Post A Followup
: Re: Re: 140 hyd pump leak
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
