Re: Engine locked up--need suggestions!!!
Posted by Bill Smith on March 01, 2003 at 14:19:04 from (128.242.4.59):
In Reply to: Engine locked up--need suggestions!!! posted by Jesse on March 01, 2003 at 13:40:34:
First off, the oil level for most engines is below the oil pan gasket. If that is the case, the bad gasket might seep a little while engine is running, but wouldn't cause the oil to all leak out while tractor is just sitting there. I would guess that the engine is froze but not to bad considering the short time frame in between now and the last time it run. Probably caused by either a leaking head gasket, or rain water got into uncovered exhaust. I would remove spark plugs and squirt in (I use automatic transmission fluid) and fill cylinders up. Then screw the spark plugs back in. If tractor is outside, make sure the exhaust is covered and you might want to drain coolant. Let the cylinders soak for awhile. You might be able to loosen it up without tearing engine down but likely you will have to eventually tear it down anyway. You would have to atleast pull the head off if replaceing head gasket, and tear down is pretty much manditory for visual expection of damage. Letting the cylinders soak is the key to getting it unfroze, so be patient.
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
