Re: 1940 Farmall H
Posted by rustyfarmall on March 01, 2003 at 23:22:19 from (207.32.13.229):
In Reply to: 1940 Farmall H posted by Jason on March 01, 2003 at 05:49:42:
An H or M farmall could have been equipped at the factory to accomadate either distillate (kerosene) or to run on straight gasoline. The distillate burners were more common because it was a much cheaper fuel. These tractors were equipped with the additional small tank to provide gasoline for starting the tractor. The straight gasoline burners can be identified by an X suffix after the serial# I have recently seen replacement caps for the small tank advertised but can't remember just where. Keep looking, I am sure you will find one.
Post A Followup
: Re: Re: 1940 Farmall H
