Re: H Grille Screen
Posted by BIG JOHN on March 02, 2003 at 15:59:43 from (205.188.209.78):
In Reply to: H Grille Screen posted by Bob Mills on March 01, 2003 at 21:32:15:
The screen is 3/16" Hail Screen that you can get from a good full service Hardware Store. Most of the chains don't carry it but they have the 1/8" and 1/4".
Just cut the screen away from the spot welded clamps and streighten the prongs and remove the screen. Use the old screen flattened out for a size pattern and cut your new screen that size. I start on one side and put it on the prongs when I get to the ribs I use a clamp type (3" wide jaws) vice grip pliers to form the screen around the ribs and then to hold it in place and I use just a small amount of JB Weld to attach the screen to the ribs.
I usually form and attach the screen completely and then go back and do the JB Weld, leaving the clamps in place until the JB Weld hardens.
This has worked well for me on several grills. GOOD LUCK!!!!
Post A Followup
: Re: Re: H Grille Screen
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
