Farmall Tractors Discussion Board
FYI engine noises
Posted by Greg Martn on September 08, 1999 at 12:13:33 from (216.128.143.209):
To locate engine noises I use a plastic transmission funnel, use the small end to your ear till you find the locaion of the noise, then reverse it with the big end to your ear to home in on the spot where the noise comes from.
I pull the plug wire from the dist. cap side so I don't get shocked, when you lose the spark from the right cyl the noise will stop.
A knock from the crank side of the con rod will have single hard rap at the oil pan level of the block then quit when the spark is removed on that cyl.
A wristpin/ broken piston will have a double knock ,it will also stop when the spark is removed. A piston skirt will get less noisey as the engine warms up,
The reason for the two knocks,when the piston reaches the top of its stroke, it pushes on one side of the cyl and when starts down it slams against the other side .
Let me kow if this helps or needs to be more clarfied, I tend to ramble a lot,..
Post a Followup
: Re: FYI engine noises
