Re: Distributor interchangability
Posted by AceS on March 03, 2003 at 16:15:43 from (205.187.80.166):
In Reply to: Distributor interchangability posted by Mike on March 03, 2003 at 09:39:29:
I think the big thing is the pin the movable point is on can be in a little location. when we put firecrator pistons in the M's SM's the pistons came with a distributor shaft to change the timing some. Other than that I think they were the same. Can't give part numbers. Hope this helps.
Post A Followup
: Re: Re: Distributor interchangability
