Re: 3-point post hole digger on H
Posted by Irv on March 03, 2003 at 16:48:45 from (152.163.189.203):
In Reply to: 3-point post hole digger on H posted by Larry F on March 03, 2003 at 08:03:18:
I put 1 on my H last year - It works great, will go down the full 4 ft. in 20 seconds or less. I have only 2 warnings about this:
1) These things are extremely dangerous. I have operated it alone, but I would not recommend it. If it got a piece of you, even a sleve or pantleg, it could get ALL of you.
2) I had a hard time getting the auger to go in square from the seat. Much better for an operator and a spotter. Also much safer.
3) I had to use a bungee cord to tie it up for transport. Otherwise it hits the ground when you transport.
4) I have a Saginaw hitch on my H. It has downpressure, and the belly pump provides plenty of power. I bough the the digger at TSC. Good luck & be safe!!!!
Post A Followup
: Re: Re: 3-point post hole digger on H
