Re: Farmall H radiator
Posted by Heath on March 04, 2003 at 18:57:31 from (208.29.50.254):
In Reply to: Farmall H radiator posted by Scott in MO on March 03, 2003 at 18:10:54:
Gary, there are 2 new radiators for the H that recently came on the market. One is a pretty good fit and the other is junk. The easiest way to tell them apart is the good one has a cast iron lower hose outlet/drain pipe exactly like the original. The other make (Northern) has a tin lower hose outlet and seperate pipe drain. The hood will not fit it, there are at least 10 measurements wrong. I hope this helps you avoid what I went through getting it all to work. (Hint- Try Steel Wheel Ranch)
Post A Followup
: Re: Re: Farmall H radiator
