Re: Wide Front Ends.
Posted by Hugh MacKay on March 05, 2003 at 03:03:15 from (216.208.58.161):
In Reply to: Wide Front Ends. posted by Dave Gibson on March 04, 2003 at 21:06:03:
Every wide front from supers through to end of 56 series will bolt up Stabilizer to frame rails may be different width on some. You may also run into different wheel bearings even if the front is from a 460. A bearing shop can match these up. You may find the same bearings on one from Super H.
I don't recomend this however if one wanted to get technical with your question. every Farmall wide front from 1939 to 1979 will bolt up from H or larger tractor, 504 being the exception.
Post A Followup
: Re: Re: Wide Front Ends.
