Re: Re: Re: Farmall serial #
Posted by Hugh MacKay on March 05, 2003 at 17:28:22 from (206.172.165.44):
In Reply to: Re: Re: Farmall serial # posted by Chris on March 05, 2003 at 16:56:35:
Chris: Your tractor has the two hydraulic levers beside throttle. Hydraulic unit is just ahead of battery, under fuel tank and on top of torque tube. The unit has rockshsfts one inside the other, that extend to just beyond fuel tank. Steel hydraulic lines run from unit to pump mounted just under distributor. Is all of this correct?
Your tractor seems to have the features of a Super A however serial numbers you are providing are not Super A Super A all had 6 digit serial numbers. Remember a good description is necessary in order for us to define what you have, and yes details do count.
Post A Followup
: Re: Re: Re: Re: Farmall serial #
