Posted by leonJ on March 29, 2009 at 11:01:48 from (66.191.76.174):
I have a 454 that starts and runs well but, when you make a sudden move to increase the throttle, it falls flat on it"s face and dies. If you ease the throttle up it is fine and runs out good. If you start out in third high, and the governor reacts to the load, the tractor also dies instantly. If I choke it as it dies, it will recover. I have cleaned the carb, installed new points, replaced the coil, checked for manifold vacuum leaks, still no improvement. The tractor does seem to run a litle on the rich side but there are no carb adjustments other than the idle mixture screw. Anyone have any input to my problem?
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
