Re: Lift-All Leaking
Posted by john on March 06, 2003 at 07:42:08 from (152.163.189.203):
In Reply to: Lift-All Leaking posted by Dagger on March 05, 2003 at 14:52:34:
these seals should still be available from IH.
I also just bought all lift-all seals and gaskets
from my local dealer about 6 months ago. you may want to go ahead and replace the 2 seals on the transmission where the clutch shaft goes in and where your shaft comes out to drive the pump, while you have the pump out. the coupler that is on the trans side, that drives the pump, may be
hard to get off. I believe it turns to the left to come off.
Post A Followup
: Re: Re: Lift-All Leaking
