Re: what size engine did the International Super A HAVE
Posted by justin on March 06, 2003 at 16:47:44 from (216.188.198.180):
In Reply to: what size engine did the International Super A HAVE posted by Jon on March 06, 2003 at 15:23:47:
The Super A actually has 3 different engines that were used.
1. C113 with small diameter sleeve seal land O.D. of 3.311"
2. C113 with large diameter sleeve seal land O.D. of 3.4374
3. C123 Used same sleeve as #2, but had a water pump.
for the Super A, engine #1 was used from 250001-310299, Engine #2 from 310300-end of standard Super A production, and Engine #3 was used in the Super A-1, which has a serial number of 356001 or higher.
Post A Followup
: Re: Re: what size engine did the International Super A HAVE
