Re: 300 utility LB
Posted by Frozen Iron on March 06, 2003 at 19:04:17 from (142.161.0.91):
In Reply to: 300 utility LB posted by klyde on March 04, 2003 at 10:04:37:
I had the same problem. The cure is to use Hytran transmission fluid. But make sure you drain every drop of old oil out and if you have the time flush out the trans and check for places where water could leak in. I doubt that it is just condensation. It is usually the planetary gear assembly that freezes tight then you can't start without clutch depressed. Believe me I have a 300U that starts easily at -35 no clutching involved. All it takes is HyTran fluid and a clean gear box.
Post A Followup
: Re: Re: 300 utility LB
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
