Re: 1486 pto
Posted by randy hall on March 06, 2003 at 21:08:51 from (209.11.237.52):
In Reply to: 1486 pto posted by Eddie on March 06, 2003 at 19:29:45:
mostly you can expect to have a lot handier tractor, but to stave off future problems it would be wise to go thru the unit you are going to use to replace the seals and check the clutch facings. my 1486 already had the two speed unit in it when i bought it
Post A Followup
: Re: Re: 1486 pto
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
