Re: String modification for governor...
Posted by Farmer Gene (WI) on March 07, 2003 at 02:26:15 from (64.91.86.122):
In Reply to: String modification for governor... posted by Tim Malin on March 06, 2003 at 14:22:26:
We used to do that when we were kids helping with threshing, we'd race with the neighbor kids to the next place. on the allis's we'd tie a twine string and the John Deere's we could reach with our foot didn't want to let the old man catch you doing that or you wouldn't be able to sit down for a week. Don't think it would be too good for the engine, over reving could cause something to let go, like a rod, and appear thru the side of the block. If your working the tractor under a load and the governor is working properly shouldn't be any need to do it.
Post A Followup
: Re: Re: String modification for governor...
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
