Re: Farmall 230 Fuel Bowl: HELP!
Posted by Michael Soldan on March 07, 2003 at 13:47:20 from (216.46.130.64):
In Reply to: Farmall 230 Fuel Bowl: HELP! posted by BobG in VA on March 07, 2003 at 13:11:13:
Bob G you have a restriction in the fuel supply. I keep some small hoses around for just such a thing. When you remove the sediment bowl and turn the fuel on you should have a substantial flow. I remove the bowl and shove a piece of rubber hose over the opening to the tank. With one hand I open the valve as I blow in the hose..this usually dislodges any crud that has floated over the hole. The permanent fix is to remove the tank aand clean it out but a piece of rubber hose has kept me going many times. I find that if I keep the tank filled on the top half I have less problems with clogs....good luck from Mike in Exeter Ontario
Post A Followup
: Re: Re: Farmall 230 Fuel Bowl: HELP!
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
