Re: milky colored oil
Posted by Paul Shuler on March 07, 2003 at 16:41:46 from (66.119.2.82):
In Reply to: milky colored oil posted by Rick on March 07, 2003 at 16:27:39:
What kind of tractor is it Rick? Could mean water getting in the oil. In my case I have a Super C that when the hydraulic pump O ring went bad and dumped the hydraulic oil into the crank case it had a very similar look as you have described. If that is what is causing your trouble it is a very easy and cheap fix.
Post A Followup
: Re: Re: milky colored oil
