Re: Re: Re: Hydraulic Question
Posted by Bernard le mécano on March 07, 2003 at 20:26:35 from (142.169.50.57):
In Reply to: Re: Re: Hydraulic Question posted by UpHere on March 06, 2003 at 12:16:27:
Hi, your suction strainer is plugged. It's on the suction line, on rear end of the pipe.Drain the oil, put a 3/4 allen tool on big plug and remove it, the strainer is inside the elbow, unscrew it and clean with solvent. Clean the elbow before for dirt.
Bernard le mécano
Post A Followup
: Re: Re: Re: Re: Hydraulic Question
