Re: Farmall 230 Fuel Bowl: HELP!
Posted by Hugh MacKay on March 08, 2003 at 02:25:07 from (216.208.58.112):
In Reply to: Farmall 230 Fuel Bowl: HELP! posted by BobG in VA on March 07, 2003 at 13:11:13:
Bob: If that 230 has been idle for some time in past, and parked with little fuel in tank. Inside of tank gets a flaky rust on it. You start to use tractor and movement of gas in tank washes this rust all down. I have seen that rust completely block inlet to bowl. If this be case best to take tank off and clean. You can just take bowl out and clean stem. This will happen about 4 times and problem will go away. There are sealers to put in tank to stop the rusting. I have never used them, some guys on YT forums have.
Post A Followup
: Re: Re: Farmall 230 Fuel Bowl: HELP!
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
