Re: starting a S-MDTA
Posted by Bob M on March 08, 2003 at 07:44:50 from (66.66.123.133):
In Reply to: starting a S-MDTA posted by Dale (MI) on March 08, 2003 at 06:00:40:
Dale - My condolences on the loss of your father...
Here's the shutdown procedure directly from an MD owner's manual - gotta think the procedure for an SMDTA is the same:
1 - Be sure gasoline supply is turned on.
2 - Retard the engine speed control lever, and at the same time pull the compression release lever all the way back.
3 - Shut off gasoline supply at the tank and allow the engine to use up the gasoline in the carburetor.
4 - After the engine stops on gasoline, push the compression release lever to Diesel position to let the starting valves cool on their seats.
Added suggestion: If the tractor has been pulling hard and is hot, let it idle for several minutes on diesel (to cool the head) before going through the shutdown sequence.
Post A Followup
: Re: Re: starting a S-MDTA
