Re: C 135 engine tune up specs
Posted by Gary-Miss on March 08, 2003 at 16:59:20 from (152.163.189.203):
In Reply to: C 135 engine tune up specs posted by Ted on March 08, 2003 at 16:07:18:
Specs should be the same as a C-113 DISTRIBUTOR engine. (.020 on the points, >032 on the plugs. Most of te manuals will tell you .023 on the plugs. This has to be a misprint, cause I can't get one to run at .023 on the plugs. With the C135 engine, there should be a mark at TDC on the fron pulley with a pointer. Set it one there on compression, set the points properly, then loosen the distributor, rotate in IN THE DIRECTION of rotation until the points close, then turn the switch on an rotate it AGAINST the rotation until the points fire.Lock it down. You may have to do this a few times to get it right. If you have a test light, leave the switch off, connect the clit to the battery source, touch the wire going to the points, kit will light up. At the moment the light goes out (th points open, lock them down.
Post A Followup
: Re: Re: C 135 engine tune up specs
