Re: Ruff running 240 Utility
Posted by Randy in NE on March 10, 2003 at 04:09:39 from (216.58.237.20):
In Reply to: Ruff running 240 Utility posted by Bill Cole/Rochester NY on March 09, 2003 at 21:45:11:
Is it dripping out of the radiator overflow? If you have recently topped off the cooling system you could be getting some thermal expansion. After you shut off the tractor the engine will still have a lot of residual heat and the water will continue to expand. There are many other possibilities depending on where it is leaking from. Probably a bad gasket.
Post A Followup
: Re: Re: Ruff running 240 Utility
