Re: What year is this H ?
Posted by rustyfarmall on March 10, 2003 at 17:49:48 from (216.248.75.146):
In Reply to: What year is this H ? posted by Dave Wis. on March 10, 2003 at 16:49:42:
Yes, you can use the casting codes to determine the date of manufacture. These codes are located on all parts made of castiron. Axle housings, clutch housing, engine block, etc., The code will consist of one digit which will be the month, one digit will be the day, and a letter which will indicate the year. Example- 2-15-K, would be February 15, 1941. The letters start with I for 1939, J for 1940, K-1941 and so on. The letter U is not used so a letter T is 1950, and W is 1951. I hope this helps.
Post A Followup
: Re: Re: What year is this H ?
