Re: Re: Re: Re: putting disc brakes on regular H
Posted by Ray in Pa. on March 10, 2003 at 21:54:06 from (205.138.20.127):
In Reply to: Re: Re: Re: putting disc brakes on regular H posted by wooh that is not supoes to be spelled that why oopps sorry on March 10, 2003 at 07:37:26:
Actually disc brakes on the farmall 300 are very powerful if they are rebuilt right. I operated my 300 for 10 years with poor brakes that chattered severely and it would barely stop under it own weight on a hill. Although sanding the pads and actuating disc's 5 years ago did little to improve them, I recently decided to take them apart to get to the bottom of the problem. What I found when mounting the actuating disc's on my lathe, Was that the actuating disc's where never originally cut true at the IH factory. The initial give away to this problem is that the actuating disc's will have very shiny high spots on them of which this is the only part that is coming in contact with the fiber disc's, thus greatly reducing stopping power. My secret to cutting these acuating disc is to get them real clean, lightly (very carefully) remove the high spots of the ball bearing ramps. Then bolt the actuator disc's together with the ball bearings in the ball bearing ramps. Then mount the pair of bolted toghter actuators on the lathe and cut one actuator disc to true it up. Then reverse to cut and true up the other actuator disc. After finished cutting them, Make sure that each ball bearing is kept track of to be put back into same ramp that it was in during the cutting process when unbolting the actuator's for cleaning. I also cut and true up the bearing retainer disc plate and housing disc area and took the appropriate amount off the brake housing to tighten up play between every thing. Although I did a few other things that probably helped some also, (Too much to explain now), This was the main stopping problem. My 300 will stop smoothly and can easily skid the calcium filled tires with a baler on back even on asphalt. Its just like having power brakes. I had thought of cutting the brakes for others, but I don't know if any money could be made since it does take time to cut them right. Thanks Ray in Pa.
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
