Re: Re: Re: Farmall H - Oil Pressure?
Posted by Steven@nd on March 11, 2003 at 06:36:56 from (12.23.184.52):
In Reply to: Re: Re: Farmall H - Oil Pressure? posted by Rodney on March 11, 2003 at 05:25:17:
Yes, a machine shop should be able to get it flat again. But I will caution you, as another post said - if the bearings are worn you still won't get any more oil pressure.
How long since an overhaul? If it has been quite awhile I would bet that the bearings are worn, causing the oil pressure to be lower.
Post A Followup
: Re: Re: Re: Re: Farmall H - Oil Pressure?
