Farmall Tractors Discussion Board
Re: IH WD9 injector pump problems
Posted by Farm-Al on September 09, 1999 at 05:57:42 from (205.188.199.53):
In Reply to: IH WD9 injector pump problems posted by Don on September 08, 1999 at 21:26:25:
DON The problem with fuel delution in your pump is very common. this can cause pump failure if you don't change oil in the pump often. My TD6 crawler had the same problem and I took the front cover off A Later model transfer pump that had A better seal set up and it helped. Worst case is no Lub. at all that is the disaster!
Post a Followup
: Re: Re: IH WD9 injector pump problems
