Re: Farmall H final drives
Posted by Steven@nd on March 12, 2003 at 16:57:24 from (12.23.184.68):
In Reply to: Farmall H final drives posted by Jerry Merritt on March 12, 2003 at 16:32:51:
An HV has final drives (drop housings) - this is a high crop model.
A regular H just has the transmission and rearend to fill. There is a plug below the PTO to drain and a plug at the front of the transmission on the bottom to drain from. You fill through the big plug by the steering pedestal and the tranny/rearend holds 6 gallons. I use 85W-140, but 90W works good too.
The belly pump should hold 6 quarts of straight 30 weight non-detergent oil (NOT 30W). Non-detergent because detergent oil will foam - 99% of the oil out there is detergent. You can also use Hy-Tran or another hydraulic fluid.
Post A Followup
: Re: Re: Farmall H final drives
