Re: Farmall H final drives
Posted by Gary-Miss on March 12, 2003 at 17:02:08 from (152.163.189.203):
In Reply to: Farmall H final drives posted by Jerry Merritt on March 12, 2003 at 16:32:51:
The operators manual I for H and HV (Hi-clearance)shows trqansmission and differential case (together) capacity is 6 gallpon. Rear axle drive housing is 3quart each side for HV (Hi-clearance) only. The book shows SAE-90. The IH Lift-all manual (GSS-5034) says," Use only clean oil of the same viscosity as used in the tractor engine. Never use crankcase drainings'.The Lift-alloil capacity will depend on what type cylinders you use (single acting or double acting) and how many.Do not fill above the full mark on the dipstick. To get the full benefiof your lift-all, you may want to buy the manual. I don't own one. Ijust have the manual cause a dealer went out of business and I bought the menuals that had been ordered, but, never picked up.
Post A Followup
: Re: Re: Farmall H final drives
