Re: Re: Super A Hydraulic reservoir leak
Posted by Gary-Miss on March 13, 2003 at 14:24:40 from (205.188.209.78):
In Reply to: Re: Super A Hydraulic reservoir leak posted by Daniel on March 13, 2003 at 13:56:10:
Piece of cake!!! Get a new gasket where the lines connect to the right side of the touch control (you called it reservoir. Buy the two "O" rongs for the control rods. Now, you're ready tpo go to work. Remove the three bolts that hold the manifold (pipes) on the right side, Disconnect the touch control rods at the bottom side(s) of the unit. Remove the fuel tank. Remove the four bolts that mount the unit to the clutch housing (3/4 inch heads) Set the unit where you can get at everything on the front (tractor front) of the unit. Remove the lift arms from the unit. Removal of the control arms from the lift arms is self evident as you get to it. Remove the control rods from the front of the unit by sim,ply pulling them out. Fashion a "pick" out of a welding rod or similar item with a hook on the end to reach in and pull the "o" rings out of there groove. Work the new "O" ring into the same groove, replace the control rod. There will be no need in pulling the head off the other end. If it were a later model with plastiv valves, I would say, do it, but, your Super A should be all metal inthere. No sense in asking for trouble. You probably need to remove the four small bolts from the left side and clean the screen and the reservoir. Be careful whenputting it back in since forcing it in can collapse it. Rethe unit on the tractor, fill with oil. If it does not imalmost immediately move the lift arms, apply a little air pressure around a grease rag to the filler hole to prime it. If, when you move the control levers to their limit, the unloader valve opens, adjust the limts on the bottom of the unit. Good luck-sTILL A PIECE OF CAKE.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
