Re: Ih 300U hyd ports
Posted by dick on March 13, 2003 at 16:02:37 from (209.244.78.145):
In Reply to: Ih 300U hyd ports posted by Brian S on March 13, 2003 at 13:00:26:
Large port in middle@top: supply line
Large port in front, half-way down: return line
Small port in front@top: control line - when blocked, hydraulic pump is unloaded (assuming no other control valves are active); when open (allowing flow INTO the control valve) the hydraulic pump loads up and high pressure fluid is available (hopefully) at the supply port
Post A Followup
: Re: Re: Ih 300U hyd ports
