Re: Farmall M Governor
Posted by randy hall on March 13, 2003 at 21:29:45 from (209.11.237.80):
In Reply to: Farmall M Governor posted by Mike on March 13, 2003 at 12:52:18:
make sure and scrape all the grease and crud that collects behind the governor housing so you can pull straight out on it and it should come out,although it is a pretty close fit. it might help if you hold your tongue just right!
Post A Followup
: Re: Re: Farmall M Governor
