Re: C or Super C ?
Posted by Hugh MacKay on March 14, 2003 at 03:56:36 from (216.208.58.188):
In Reply to: C or Super C ? posted by Mark in Mississippi on March 13, 2003 at 11:16:09:
All this discussion is great guys, but after 50 years of modifications, building one tractor out of two, there is probably no way of knowing for certain. All of the main castings will bolt up one to the other, making all items interchangeable. Every single item listed in preceeding posts could be added to a C with some modifications and a bit of work.
I like many of you thought serial number was a fool proof way of knowing. There was a guy on forum about a week back with an A or Super A. Serial numbers both on tractor and engine although not close say it is an A. However it has a full set of factory hydraulics. Explain that one if you will.
Post A Followup
: Re: Re: C or Super C ?
