Re: M Horsepower and Weight
Posted by Doug in OR on March 15, 2003 at 08:52:10 from (12.225.51.197):
In Reply to: M Horsepower and Weight posted by Bud on March 14, 2003 at 18:14:07:
When you see those Nebraska test results, you need to bear in mind that the weight is the "as tested" weight. Sometimes they look for a compromise to put as much hp to the ground as they possibly can - and may add 1000's of pounds of weight to do it. Look in the original specifications under "shipping weight" if you want a more accurate weight number. As for HP in that particular test, I suspect they didn't have the ratio set up correctly and had to pull in a less efficient gear. Look at the Super M results - the difference is too great.
Post A Followup
: Re: Re: M Horsepower and Weight
