Re: Carb Adjustment Farmall 400
Posted by Bob M on March 16, 2003 at 07:21:43 from (66.66.123.133):
In Reply to: Carb Adjustment Farmall 400 posted by Scott(TN) on March 16, 2003 at 06:22:11:
Scott - A couple easy things to try first: Remove the air inlet hose at the carb. Make sure the choke opens all the way when the knob is pushed in - adjust the cable if it does not. Now run the motor with the air hose off. If it runs better, the air cleaner is plugged and should be cleaned. If that doesn't help, run the bottom carb adjusting screw (high speed adjustment) in all the way. Then back it out 1 turn and try the motor again. If this helps, adjust this screw in or out as required for best running at full throttle. The upper screw is the idle mixture adjustment. If turning it in/out has no effect on idle speed/smoothness, it means the carb idle circuit is plugged. Only fix is to remove, disassemble and thoroughly clean the carburetor. Finally another possibility is the cam drive gear key has sheared. This causes valve timing to drift resulting in loss of power and black exhaust. It may cause the spark timing to jump around as you observed. It may also be accompanied by a knocking sound from the front end of the motor when idling. And if you remove the hydraulic pump you may sometimes (but not always) find the cam gear inside can be moved a bit under finger pressure. The only solution is to remove the tractor front end, timing cover and cam gear, then installing a new key. Not a difficult job but requires removing large/heavy parts to get to it. (Note: This seems to be a common problem with 4 cylinder Farmalls with live hydraulics - it's happened to my Super M, also to a buddy's SMTA and 400.) Good luck!!
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
