Re: axle seal leaking
Posted by Gary-Miss on March 16, 2003 at 08:39:57 from (64.12.97.13):
In Reply to: axle seal leaking posted by shaggy on March 15, 2003 at 22:13:33:
If you can get by with it, you might leave the seal out a little way. The new seal will probably take care of the problem. J0B weld will also take care of it. Make sure it is CLEAN_CLEAN>
Post A Followup
: Re: Re: axle seal leaking
