Re: Re: Re: Re: Re: Re: Re: Farmall M won't turn over.
Posted by Got her to turn over!!!!!!!!!! on March 16, 2003 at 09:12:02 from (209.183.116.146):
In Reply to: Re: Re: Re: Re: Re: Re: Farmall M won't turn over. posted by Hugh MacKay on March 16, 2003 at 03:15:20:
I had two wires on it. The wire going from the battery to the starter, to turn it over. Finally found the culpret. Had a little red wire between the starter, and the starter wire {two on the same connection}. Read what you guys wanted me to do. Put the charger on the battery in case I wanted to test it. Thought to myself, ought to try to take this wire off {ran from the starter to the alternator}, and see what it would do. Took it off, tightened the bolt down, hit the starter, and she cranked over easy as can be, till the battery went dead. THANKS FOR THE HELP GUYS!!!!!
Post A Followup
: Re: Re: Re: Re: Re: Re: Re: Re: Farmall M won't turn over.
