Re: Re: Re: Starting an M for the first time after overhaul? Need help!
Posted by Doug in OR on March 17, 2003 at 06:12:45 from (12.225.51.197):
In Reply to: Re: Re: Starting an M for the first time after overhaul? Need help! posted by Farmall Daddy on March 17, 2003 at 05:34:55:
You can set the valves when it is warm and not running, but I've never had any problem setting valves while the engine was running. There is a chance that your ignition system is at fault - either the coil or mag - is shorted and it gets worse when it warms up. My first answer was based on the assumption that the tractor ran fine before the overhaul.
Post A Followup
: Re: Re: Re: Re: Starting an M for the first time after overhaul? Need help!
