Transmission oil in 350
Posted by dhermesc on March 17, 2003 at 09:16:15 from (204.233.53.98):
I have seen several posts about how the rear end of the 350 should be filled with Hytran instead of 80W due to the TA. I have been running mine with 80W for about 2 years with no problems, but it sees very minimal use in the winter and the TA is never used then. Am I creating a problem for myself or should I not worry about it? From what I can tell the oil (and water) I drained was very old (original?) and even with that crud everything seemed to work OK.
Post A Followup
: Re: Transmission oil in 350
