Re: Re: Re: Re: What kind of oil goes in a belly pump for a Farmall H
Posted by CNKS on March 17, 2003 at 14:14:23 from (207.178.96.211):
In Reply to: Re: Re: Re: What kind of oil goes in a belly pump for a Farmall H posted by klf on March 16, 2003 at 21:22:44:
I didn't say W did not mean winter, just that you won't find it associated with a single grade SAE 30 oil, as SAE 30 is used in the summer, or year around in warmer climates. As I said most people including myself say 30 weight or 30W, using the W incorrectly to mean weight. Also heard that SAE 30 develops more pressure in a belly pump because it is not as thin as Hy Tran. Also fewer leaks. Belly pump is not very complicated and does not require hydraulic fluid. As was mentioned, use Hy Tran if sharing implements with modern tractors.
Post A Followup
: Re: Re: Re: Re: Re: What kind of oil goes in a belly pump for a Farmall H
