Re: model H ring gear
Posted by Larry F on March 18, 2003 at 21:44:15 from (216.202.132.34):
In Reply to: model H ring gear posted by jeff on March 18, 2003 at 17:22:19:
Jeff - The ring gear will generally come 'to rest' in approx. the same location the majority of time and the teeth in that area will show the greatest wear. Some posters on this forum have successfully avoided replacing the gear by carefully heating it while in the tractor and then using a brass drift and hammer to rotate the gear on the flywheel.
Post A Followup
: Re: Re: model H ring gear
