Re: Field Circuit Resistance on an H
Posted by Steve - IN on March 19, 2003 at 02:54:21 from (12.222.31.186):
In Reply to: Field Circuit Resistance on an H posted by Hollerback on March 18, 2003 at 19:21:37:
Hollerback, I'm guessing you have a 4 position light switch, and that the system originally had a cut out instead of a regulator (had a two wire box, now has a 3 or 4 wire box) - and that you're not talking about the headlight dimmer resistor - and are using a 12 volt battery. If so, the purpose of the big field resistor between the switch and the field or F terminal on the generator is to keep the generator from overcharging the battery -- effectively making you the regulator when you saw the ammeter in high charge mode for too long -- you switched in the resistor, or switched it out when you needed more charge. Now that you have a regulator installed, and assuming it can control the old generator, the regulator will take over the job that the driver was once expected to do. The F terminal of the regulator goes to the F terminal on the generator. Instead of going to a cutout, the A or armature terminal of the generator now goes back to the Gen terminal of the regulator (the odd man out, as the other two or three are on the other side of the box). The Batt terminal on the regulator runs through the ammeter to the battery, and if you have a L or load terminal, it runs through a fuse and to the lights via the light switch. If your system is hooked up that way, and the regulator is polarized and doing its job, you should be OK. No field resistor needed. The two pole box, the cutout, was there to keep the the battery from draining into the generator at low speed. The regulator basically adds a second relay to the cutout setup and keeps the generator from under or over charging the battery -- as you've said. If you've converted to a 12 volt battery and still have a 6 volt coil in a coil/distributor setup (not a magneto) you'll need about a 2 ohm resistor rated to handle about 50 watts to drop the ~4.5 amp draw of the coil down to around six volts. If you have a magneto, no worries, it's independent. If you're talking about the light dimmer resistor - that curly thing - 3 lights will draw about ~4 amps each, ~12 amps total, or 144 watts at 12 volts. If we want to drop down to "half speed", ohms law says: Current= square root of power / resistance which says 12 amps drops to 6.0 amps with a 4 ohm resistor - which is different than the ~1-2 ohm resistor that was there for the 6 volt setup. If none of my guesses are right - and you have basically a cutout so you still need the field resistor -- you can figure the resistance needed by Ohm's law above. Let's guess that your generator puts out around 20 amps at 12 or so volts, for around 240 watts of power. If you have a coil/distributor, you're going to have a draw of 4 to 5 amps to run the engine. If you have a magneto, no draw, it makes its own power. So if we want to be able to take the 20 amps down to about a nice, gentle 3 to 5 amp trickle charge with no lights on a magneto tractor, or around 7 amps if we have the draw of the coil ignition system. This is to keep the battery from frying when you run for a long time, and that ammeter has been reading +10 or +20 for way too long. So back to Ohm's law again -- taking 12 volts at 20 amps down to 7 amps requires just a shade under 5 ohms. With a magneto making no draw you need about 20 ohms for a 3.46 amp charge rate. To charge at ~5 amps, you need 9 ohms which works out to 20 amps in, 5.16 amps out. If you measure the output of your generator at working RPM's and read up on the recommended charge rates for the battery you're using -- you can select the resistor value to taste using Ohm's law and your knowledge of how you'll be using the tractor. There's no hard and fast, "must have" number for the value of the resitor. Hope that covers all the possible bases, and answers your question as well. Steve
Home
| Forums
Today's Featured Article -
Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
