Re: if the carb is bad
Posted by Rick P on March 19, 2003 at 05:46:22 from (208.10.138.55):
In Reply to: if the carb is bad posted by Bill L Md on March 17, 2003 at 16:49:17:
Bill try putting gas in each cyl. thru plug hole if it fires then I think you have intake problem bad gaskrt somewhere. Hope this helps Rick P
Post A Followup
: Re: Re: if the carb is bad
