Farmall Tractors Discussion Board
Re: farmall 1206 engine
Posted by Earl on September 09, 1999 at 21:52:39 from (206.28.32.175):
In Reply to: farmall 1206 engine posted by brad on September 09, 1999 at 14:57:32:
Brad, because these engines use the same connecting rod either the piston pin location on the piston or the deck height of the block will be different. The camshaft is different also but the cam bearing are the same so you would need to check lift specs also. This project may be feasible but appears costly.
Post a Followup
: Re: Re: farmall 1206 engine
