Re: super A overhaul
Posted by Jim on March 19, 2003 at 08:00:48 from (216.82.158.216):
In Reply to: super A overhaul posted by Hal` on March 18, 2003 at 17:43:22:
Hey there. I'm in the process of rebuilding my Super A, only painting left. I just put a new head on mine and had no compression because the valves were too tight (not closing) so all the compression was going right out the exhaust and intake. I would do a compression check first if you have a compression tester, and if that is good check the ignition timing, wiring, points, rotor, cap, etc.
Post A Followup
: Re: Re: super A overhaul
