Re: 400/450 lp manifold
Posted by Red Rider on March 19, 2003 at 19:49:27 from (66.248.100.164):
In Reply to: 400/450 lp manifold posted by Dave on March 19, 2003 at 17:45:42:
Yes it would fit your tractor and it will make more HP. If you haven't seen one before it is exactly the same as your gas manifold except the intake and exhaust are seperate, not connected. This allows for a little cooler more dense air to be drawn into the combustion chamber. It is pretty simple to convert a gas intake/exhaust to a propane style set up. I converted mine by simply cutting out the section that connects both manifolds together. used a disc sander to smooth it up and you could not tell the difference in a factory LP set up. To buy a factory LP intake/exhaust from a salvage yard if you can find one will cost you 300 bucks or more.
Post A Followup
: Re: Re: 400/450 lp manifold
