Re: Carb in BAD shape - help
Posted by Gerald on March 19, 2003 at 19:53:09 from (66.94.138.50):
In Reply to: Carb in BAD shape - help posted by Jeff_MI on March 19, 2003 at 17:26:01:
Jeff,
Your carb sounds like a real challenge. I have had similar problems. I sprayed blaster penetrating oil on the screws then used narrow vise grips to turn the screw heads. Worked for me. Looks like you are going to need a carb rebuild kit. I have had good luck using the services of Treadwell Carburator Co. in Treadwell N.Y. They can rebuild it for you or will supply you with a new or re-built one. Best of luck to you.
Post A Followup
: Re: Re: Carb in BAD shape - help
