Re: Re: 'C' BRAKES
Posted by I RIGHT I on March 20, 2003 at 08:54:05 from (170.54.59.160):
In Reply to: Re: 'C' BRAKES posted by Randy in NE on March 20, 2003 at 07:27:30:
It seems to be leaking from the trans. case,I have the bolt,washer,and rubber gasket off,but isn't there a seal behind the drum in the trans. case? This would be for the splined shaft that the drum is on, IRI
Post A Followup
: Re: Re: Re: 'C' BRAKES
